Uh guys, can I get a little help?
Old Jan 8, 2010 | 11:40 AM
barnat's Avatar
If you got the time Extreme,,,,, before you put the new crank bolt in? Ide maybe pull the timing cover to see if theres any drag marks on it from the timing chain from you turning it over by hand (JUST) to make sure you have enough clearance in there.Sometimes its better to be safe then sorry later Glade you got it broke loose though
