-8 hose for breather tank?????
Old Jan 7, 2010 | 02:51 PM
2002RamAir's Avatar
Default -8 hose for breather tank?????
What hose is best for a breather setup from the valve covers? Im using two factory driver covers with -an fittings welded in them. The breather tank has 3/8 npt ports. Would -10 be overkill for those ports or would -10 be the best to use?
Old Jan 7, 2010 | 03:02 PM
ninetres's Avatar
I have a -10 on each side plus the little stock one and I still blew my dipstick out a couple passes at the end of the season. Could be a bit too much blowby on my car but I would still run -10s.
Old Jan 7, 2010 | 03:13 PM
BIG_MIKE2005's Avatar
At what point does boost dictate line size to properly evac the crankcase pressure?
Old Jan 7, 2010 | 03:24 PM
05TurboCGM's Avatar
LOL...I was thinking the same thing.
Old Jan 7, 2010 | 03:51 PM
ninetres's Avatar
Too many variables to say XX amonut of boost needs an XX size line. Thats why I say run a -10. No need to save $50 measly bucks and undersize it.....only needing to replace it the next year as you add HP.
Old Jan 7, 2010 | 05:31 PM
2002RamAir's Avatar
Good point... HP is like a drug. Im gonna do the -10 and be done!
Old Jan 8, 2010 | 01:03 AM
DeltaT's Avatar
I agree with the -10 but don't believe the 3/8" NPT fittings will support a -10. There will be a stepdown in the NPT/AN adapter that will effectively make the -10 a -8.
So you either need a different breather tank or I would go with two separate -8 lines. Otherwise you are wasting your money on -10 fittings and hose while still dealing with a -8-sized hole.
Jim
Old Jan 8, 2010 | 05:30 AM
2002RamAir's Avatar
Where could I find a good dual fitting catch can? Everything at summit is all -12 or 3/8 npt fittings.
Old Jan 8, 2010 | 06:03 AM
RexDiablo's Avatar
Is it enaugh with just a breather tank? I ment i read that i needed some kind of vacuum. Even when im in boost.
Do you guys mean that its neccesarily to have two seperate -10 lines to the tank?
EDIT: the thread below answered my question =)
Old Jan 8, 2010 | 03:13 PM
DeltaT's Avatar
A -12 to -10 adapter fitting is easy to find, but check the Canton Racing catalog also, I think they have a dual -10 tank. Summit may just not show it in a search.
Jim
