347 in the 5's ? ok guys here's the scoop as of now i have a 347 shortblock....stock crank forged h beam rods and wiseco -11cc dish pistons....needing advice on what heads & cam to go with....topped of with a vic jr and a 90mmtb....and a master power mp4598 turbo....we have a lot of guys running an 8.5 tire class around here....needing to get this car into 5.60's in the 1/8th....what do you guys think? i know that the turbo will have to be changed but im looking to get the bugs worked out with this small turbo then step up to a bigger one say a 80-88mm? |
It is definitely possible, my car has been 5.96 on a stock shortblock/heads and 60'ing like a turd. If the car is light enough you could go that number on fairly small turbo. |
Originally Posted by 19trans_am98
(Post 12741515)
ok guys here's the scoop as of now i have a 347 shortblock....stock crank forged h beam rods and wiseco -11cc dish pistons....needing advice on what heads & cam to go with....topped of with a vic jr and a 90mmtb....and a master power mp4598 turbo....we have a lot of guys running an 8.5 tire class around here....needing to get this car into 5.60's in the 1/8th....what do you guys think? i know that the turbo will have to be changed but im looking to get the bugs worked out with this small turbo then step up to a bigger one say a 80-88mm? You will need an 88mm unit to reach that level of performance. A MP unit will not make any power close to what you need. If you push it, then expect it to come apart. 88mm is good for solid 5.4's with a properly set up car. And faster if everything is perfect. |
I went 5.9 with my old setup, and I pretty much didn't know what I was doing. :) I'd buy aftermarket heads with a thicker deck they won't lift as easily as stock heads. |
What are some other 5 sec 347 combos? Anyone do it on spray much? |
Originally Posted by black98ws6ta
(Post 12741770)
I've had two in the 5s with a 347, LS6 intake, smallish cam etc but I used a procharger. 60' is the tough part when looking for 5.60s, I'm sure its possible with the right turbo and a light enough car. |
Good to know. been trying to decide whether or not to leave mine as a nitrous setup or go turbo. Looking for 5's to be competitive in a local 'street car' class here in Iowa. Mid 5's should get me solidly in the field. |
Does the class limit you to a certain size turbo wheel limit or pill size? |
Not at all. Any engine combo, any power adders. Stock style suspension, no wheelie bars, drag radial or 10.5 tire. Low payout to keep out the heavier hitters. |
Originally Posted by Sandmann120
(Post 12756858)
What size turbo? Any more details on your build? https://ls1tech.com/forums/forced-in...hortblock.html |
| All times are GMT -5. The time now is 09:20 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
