Procharger Relocate Brackets.
Old Jan 17, 2010 | 08:45 PM
josepy121380's Avatar
Default Procharger Relocate Brackets.
When I bought my kit it did not come with the relocation brakcets. I need the dimensions of the one for the cruise control. Any help would be appreciated.
Old Jan 17, 2010 | 09:03 PM
blk00ss's Avatar
You don't "have" to have a relocation bracket. I've got some pics of what I done with my cruise control box I'll post up later tonight. I just re-used a existig hole in the frame. It's only held up with one bolt instead of three. But it's pretty tight and doesn't really have anywhere it could go if the bolt was to come loose.
Old Jan 17, 2010 | 09:22 PM
great thanks. only think is my wire will not reach far enough. so any other ways it can be done would be good to know.
Old Jan 17, 2010 | 09:25 PM
blk00ss's Avatar
The wire will reach. Just follow the wire up into the engine bay, and there will be a plastic clip. Just pop it loose and it will give you a few more inches of room to work with.
If you dont like the idea of just one bolt holding it up, a zip tie would do good going through a hole in the frame around the wire coming out of the back. YUou will figure somthing out when you get to looking
Old Jan 17, 2010 | 09:30 PM
thanks a lot. i will try that. my car is a trans am though. might be a little different.
Old Jan 18, 2010 | 05:20 AM
EPP's Avatar
EPP
You should be able to do the same thing. Bob
