106mm turbo .
Old Jan 20, 2010 | 02:29 AM
street_tuna's Avatar
Default 106mm turbo .
Hello ,
I have motor that jusy finshed and its for drag race only ... so what i need to know is what size A/R that every one is using for that kind set up .
the motor is :
436ci lsx block
etp 255cc heads .
wet sump kit on it .
sold cam .
and do i have to use two 60mm W.G so i can control the boost right on it . or just one 60mm will be fine with it .
and what is the best gears you are using for the 1/8 mile i have 3.55 right now on my M9 rearend .
Thanks for the help .
Old Jan 20, 2010 | 08:31 AM
Phil99vette's Avatar
7 Second Club
1.32, 3.5 with 30" tires.
Old Jan 21, 2010 | 01:37 AM
isnt 1.32 to big for the kind set up ... and am using 29.5 x 10.5 hoosier will the 3.5 will work on it .
Old Jan 21, 2010 | 05:44 AM
Fireball's Avatar
if you have a matched setup...the 1.32 will work just fine with a 43x motor...thats what Phil uses on his 438....spools VERY fast
Old Jan 21, 2010 | 09:34 PM
venom ws7's Avatar
Listen to Phil and Fireball they know what they're talking about
Great setup BTW do live in Kuwait?? Are you building this for Bahrain or Qatar??
Old Jan 23, 2010 | 07:18 AM
veee8's Avatar
Went with a 1.32 A/R and 30" tires for my my 427 and 106mm this year.
Old Jan 23, 2010 | 09:26 AM
Steve Burger's Avatar
LS1TECH Sponsor
We just talked with Precision on this. The recommendation is 1.32 for a footbrake car. It will spool faster. They did say the transbrake car can take advantage of the 1.50 AR depending on converter and RPM range.
Old Jan 23, 2010 | 10:21 AM
6techniques's Avatar
+1.5million
What car are you running this setup in?
Old Jan 23, 2010 | 12:11 PM
7 Second Club
On a 427-438? I highly doubt you'll see anyone running a 1.50 AR and going fast with a 427-438". Maybe on a 525-550" big block.
Old Jan 23, 2010 | 02:34 PM
Shawn @ VA Speed's Avatar
Yeah,a 1.50 isn't going to work properly on a small block.well maybe it would with one of those inefficient converters that have 25% slippage
Old Jan 23, 2010 | 04:48 PM
ta02zx10r's Avatar
are you the same "street tuna" that did the gen tt kit?
Old Jan 23, 2010 | 11:36 PM
no am jassim from kuwait .... my user used to be firehawk123 but am traying to get it back because i lost my email and my password hope i can get back soon .
so steve 1.32 will be the best option for my set up . and as far as i know that the engin is in the shop and the hot parts on the way to the shop and the wet sump to .
but i heard that for the 1/8 mile need somthing lower that 3.55 like 3.73 .
Old Jan 24, 2010 | 11:07 AM
TwnTrboCE's Avatar
There had to be some confusion there... Unless your running a very loose converter. Leaving at 6,000 rpm and shifting it at 10,000. There is no way a 1.50 will work WELL on a small block car.
Tuna, a 1.32 is what you want. I would stay with the 3.55 as well. We run a 3.50 with a 315 radial with a 3spd. And are near the top of 2nd in the 1/8th.
Old Jan 24, 2010 | 02:51 PM
7 Second Club
I dont know who your talking to but 3.73s is bad advice for a turbo car. Run 3.50s and call it a day.
Old Jan 25, 2010 | 08:26 AM
LS1TECH Sponsor
Yeah we have the engine and oil system.
I was just telling you what PTE told me. I will defer to the wealth of knowlege here on the AR.
Old Jan 25, 2010 | 01:48 PM
Thanks every one , i spock with chuck and i told hem to go a head and order the 1.32 A/R 106mm .
but what am woryed about do i have to use two 60mm W.G so i can controll the boost more better .
Old Jan 25, 2010 | 01:55 PM
7 Second Club
I've got twin 44mm gates and can run the boost down to 4# without any creep. If you set the wastegates up correctly you dont need two 60s. One would probably work IF setup correctly.
Old Jan 26, 2010 | 06:11 AM
Thanks Phil for the info .. i think that am going to but 2 W.G 60mm .
