New PB
Old Jan 21, 2010 | 08:30 PM
MY99TAWS6's Avatar
Would like more details about car. What rear end gearing? 4l80e? What exact suspension mods,front and back of cars..what tires ,size ,make?
Old Jan 21, 2010 | 09:20 PM
turbo_ase's Avatar
Congrats...nice runs......I'm almost there.....
Old Jan 21, 2010 | 09:23 PM
venom ws7's Avatar
Originally Posted by 98Z28CobraKiller
Al-Anaabi (sp?) rented the track all last week to test and tune their top fuel dragster. This facility is truely badass. Brand new 1400' of concrete wrapped in top fuel rubber last night. Temp was in the high 60's and damp. Not the best air. Probably around 0 DA.
Al-Anabi is buyine all kind of 7-4 sec cars
Old Jan 22, 2010 | 07:37 AM
raymond mckinney's Avatar
Congrats on the new best, glad you did hurt it when it went up!
Old Jan 22, 2010 | 07:58 AM
98Z28CobraKiller's Avatar
Restricted User
Originally Posted by firstinlastout86
***** sick los, you are my hero!! Was this run last night? Cat and I were gonna head out but we got caught up putting on her slp underdrive pulley.. If it was last night I herd there was alot of down time/break downs
I got 4 passes in. The delays were all towards the end of the night. Next time you guys come out, swing by and say hello. I always pit right up front next to the stagging lanes.
Originally Posted by Snyper
(fix your sig)...and congrats. Your car is a beast.
Fixed and thanks
TH350 w/ RMVB and transbrake that only half works. Steel drive shaft into a S60 rear with 3.73 gears. Running a 165/15 on a 15x3 in the front and a MT Drag radial 325/50/15 in the rear on a 15X10, Pro Stars. Up front I have a turbo kmember with stock a-arms and QA1-R single adjustables. I believe I'm running the 275 springs. In the back I am running the Comp Eng 3 way adjustables in the middle setting and Eibach springs that I bought from SLP a few years back. There isn't much MPH left in this setup. I am going thru the traps at about 7200 RPM. I really dont want to spin 3rd gear that high so I will be switching to the 3.55's when I get some extra change.
Those cats have MAD MONEY. They have some beautifull rigs.
No oil under the car so it must be ok.
Old Jan 22, 2010 | 08:56 AM
darooke's Avatar
Wow, I love reading your updates. That is moving. What was your qa1 adjustments set at?
Old Jan 22, 2010 | 10:35 AM
jleews6's Avatar
Cars running great. Your car has run good even when it was a dead stock motor. Taking your time and sneaking up on it is the way to fly and at the rate your going 150 MPH is comming real soon.
When you go to the 3.5 gear I think its going to pull the MPH even better.
Congrats on putting together a simple combo that works great! Oh ya my Moroso speed calculator says its around 950HP=== WOW!!!!!!!!!!!!
Old Jan 22, 2010 | 01:05 PM
IT_SS's Avatar
Whatever it takes to go 146.7 at 3850 race weight.
best answer ever
 Michael S. Palmer
Old Jan 24, 2010 | 12:16 AM
Restricted User
Here's the video of all the other passes I made that night. First one is on 12-13 psi. Then 15 and finally about 16 psi on that last one.
http://www.youtube.com/watch?v=Mwqeuvv_nlo
Old Jan 24, 2010 | 08:20 AM
00SS4780's Avatar
Nice. Car is flying !!!
Old Jan 24, 2010 | 09:03 AM
Krazy98Z28's Avatar
What blow off valve do you have??
Old Jan 24, 2010 | 09:58 AM
  #32
Restricted User
All the way soft. I need to tighten them a bit. Last time out I tightened them up about half way and my first pass on low boost it came out beautifull. Second pass I turned up the boost a little and it shook the tires so hard that I thought that I broke an axle or sheared the lugs and fully expected to see one of my rear tires come rolling past me.
50mm TiAL Q
Old Jan 24, 2010 | 10:53 AM
  #33
Tzion_ben_Arthur's Avatar
you are helping me get thru the winter here in OK. Thanks!!!
Old Jan 24, 2010 | 11:06 AM
  #34
how many pass do you have on your TH350?
Old Jan 24, 2010 | 03:08 PM
  #35
Restricted User
It was built 6/2007 and I daily drove the car for the first year and a half with the 408 and 400 shot. I'd say well over 100 passes on the transbrake.
Old Jan 24, 2010 | 03:19 PM
  #36
Old Jan 24, 2010 | 03:55 PM
  #37
V-seriesTech's Avatar
Congrats pimpin. Cars rippin for sure.
Old Jan 25, 2010 | 05:53 PM
  #38
Restricted User
I was able to track down a couple pictures of the 9.36.
Old Jan 25, 2010 | 11:59 PM
  #39
Reject's Avatar
nice man, your ***** knocking on the 8 second door
Old Jan 26, 2010 | 05:01 AM
  #40
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Great job on the 9.36. More boost and less weight will get you an 8.9X
