Compression ratio dilemma
Lately I have heard alot of guys say its going to be a complete turd out of boost. Now of course if this is true I will have to change seveal things on my motor Oh well its only money right! FML! Anyway what has been everyones experience with a turbo LT1 or LS1 for that matter with 8.5-1 compression. I plan to run about 15-20psi to reach my power goals. Thanks
__________________
the reason why i went with such low CR, is because i am aiming for high hp on pump gas and no meth
it is easy to up or lower the CR in the ls series motors. you just change the heads. 243's have a smaller combustion chamber and that will raise the CR and 317 heave a bigger combustion chamber and that will lower CR.
Jim
its not like its a small engine or anything !!!! And the fact its an auto, the engine will likely always be using higher rpm's etc anyway
__________________
with that being said why don't you go with t76 and at least a 9.x cr? and a gtx cam?
Im running some very nice AI heads (200cc), AI turbo cam 225/225 114+4 LSA .350/.350 lift and AI ported intake with 58mm TB. Should be a pretty mean combo when combined with the PT88 and my stalled auto. Thanks for all of the responses.
For a primarily street driven turbo car that sees mostly pump gas I would keep it around 8.5-9.0:1.
