cam help with my lt1!
Old Jan 31, 2010 | 02:31 PM
4SFEDZ's Avatar
Default cam help with my lt1!
ok im thinkin bout changing my cam, right now its 570 610 236/244 on a 112, and done good so far, but now im upgrading some stuff and lookin to see if there is anything to gain by switching? im stayin hyd roller and still have a stock comp so 7k rpm will be about the limit! not sure if or how lt's and diff than ls's!
Old Feb 1, 2010 | 01:05 AM
DeltaT's Avatar
It sounds fine for the range you are talking about. What are you changing?
Jim
Old Feb 1, 2010 | 11:25 AM
4SFEDZ's Avatar
im goin from a ported stock head that flowed about 290 to a ported afr 220 that flows 330ish. and goin from a stock lt1 intake to a heavily ported lt4. goin to race gas, A2W, and more boost!
Old Feb 1, 2010 | 07:40 PM
Z28&WS6's Avatar
this is for a turbo car right? your cam sounds similar to a blower cam but i think people run good numbers on turbos with them also. call cam motion and see what they recommend. i would bump up the intake lift on it a little though. sound like a good set of heads you are upgrading to. maybe more will chime in.
Old Feb 1, 2010 | 07:52 PM
4SFEDZ's Avatar
ya its a lpe blower cam, done very good so far. just seeing if there is anything more to gain since im putting on better flowing heads.
who at cam motion should i ask for?
Old Feb 12, 2010 | 12:24 PM
NastyZ06's Avatar
Who is doing the AFR 220's for you?
Old Feb 12, 2010 | 06:30 PM
engineermike's Avatar
Cam Motion will undoubtably recommend a reverse-split cam that will undoubtably make less power than the one you have.
Did you mention what turbo you're running?
Old Feb 12, 2010 | 09:47 PM
4SFEDZ's Avatar
i got them from big purple on here, not sure who did them, i think thunder racing.
Originally Posted by engineermike
Cam Motion will undoubtably recommend a reverse-split cam that will undoutably make less power than the one you have.
umm, not sure. right now a s475, but bout to upgrade it to a 88mm wheel!
