cam help
Old Feb 6, 2010 | 08:27 PM
daws222000's Avatar
Default cam help
Is it worth degreeing new cams, if they are shelf grinds. I know older cams were off a little but the new ones are suppose to be more accurate. Has anyone had any cames off even know it was ligned up right?
Old Feb 6, 2010 | 11:29 PM
DeltaT's Avatar
"Trust but verify" is very useful when modding motors. You need to be the final judge that everything is correct in your build because it makes troubleshooting a whole lot easier. Otherwise if you have a problem you'll need to wonder if your cam is correct.
Jim
