centrifugal and turbo
And you mention compound turbocharging. Read up why this is used, before thinking about it, as its another dumb idea.
The only sensible 2 blower option, is one where each type of blower compliments the other. Not holds each other back.
You need one that will assist power in the lower rpm range. ie a PD type blower ( or small turbo )
And one that will then carry power through the upper rpm range. ie, centri or turbo
Anything else is just dumb
The only time I would use a centrifugal supercharger with a turbocharger would be in a Duramax diesel. Put an F1 Procharger with a small pulley (2-3psi at idle??) blowing into a large turbocharger. No lag, but tons of power everywhere
. And you cant just gear it up to spin faster. You can only spin any supercharger so fast, before damage might occur.
Why would a centri do the same as a PD, when they are so completely different ?
A V1 is small.
Edit: And I can imagine it being relatively dangerous all that boost hitting at once...o my. lol
If there is no restriction after the blower, that air will de-compress again.
The restriction is the engine, and the blower needs to be shifting a lot more air than the engine can consume in order to make boost. With a small blower, it just aint gona happen until the blower really comes on song.
Centrifugal charger
Turbo
see the similarities? I'm sure you know what a PD blower looks like, since you said you've worked with them. Most centrifugal blowers still don't have the low end grunt that a positive displacement blower has, mainly because they have to spin up to several thousand rpm to really get going. hell the little P1 will spin to 65,000 rpm.
Just thinking of alternative ways to achive the same goal......
Chris.
http://www.spracingonline.com/store/...ool_Valve/3659
and here is a link to Zombies building, using a similar vlave:
https://ls1tech.com/forums/forced-in...ke-graphs.html
If you google it there is some more info.
Chris.
but I will for sure be doing a gt88 with this! thanks man!!!
