car wont run in closed loop??
Old Feb 21, 2010 | 07:12 PM
KILLER-LS1's Avatar
Default car wont run in closed loop??
So im having this really weird problem, when the car is cold, it runs great, but when it get to operating temperature (im guessing when it goes into closed loop) it doesnt want to run right, and it goes super lean. However, if i immediately go WOT (computer comes out of closed loop for WOT iirc), it still runs great. I have changed the plugs, wires, and coils, and it is still doing this. Im only running two 02 sensors, one for each bank before the turbo.
i have the ebay turbo kit if that helps..
and all my sensors are reading good on my scan tool
coolant avg 180*
intake air temp avg 70*
and it doesnt look like its pulling timing or anything like that....
anyone have any ideas???
i had this car dyno'd at a local shop and we cant seem to figure it out. he is using HP tuners on a 2bar SD tune.
Old Feb 21, 2010 | 07:52 PM
KILLER-LS1's Avatar
just a thought.... can i drive it with the 02 sensors unplugged? maybe that will keep it from going into closed loop?
Old Feb 21, 2010 | 08:36 PM
XtremeDime's Avatar
If you dont have o2s the computer will only used open loop. Most of us run purely open loop because of how inaccurate the o2s seem to be.
Old Feb 22, 2010 | 11:45 AM
KILLER-LS1's Avatar
Okay thanks, I'll try that today and see if it helps!
Old Feb 22, 2010 | 06:20 PM
KILLER-LS1's Avatar
ok, so i unplugged the 02's and the problem is still there... i talked w/ my tuner and he said the car is tuned for open loop anyways. now i have no idea whats going on...
Old Feb 22, 2010 | 06:42 PM
HUNTER02SS's Avatar
Do you have a check engine light?
Old Feb 22, 2010 | 07:09 PM
KILLER-LS1's Avatar
no codes..., i typed "turbo lean part throttle" on google and i guess a lot of import guys have this problem... is it possible that im getting too much boost at part throttle, that its making it lean out? they are calling it "part throttle over boost"
i have a 404ci with awesome CNC'd heads (West coast racing cylinder heads) all on a 76mm with an .81 a/r housing. i know its "small" but this is a street car, i want it to spool fast
Old Feb 23, 2010 | 06:58 AM
darkhorizon's Avatar
PLEASE get a wideband, and some way to scan this thing...
The only way you could know if it is or is not in open loop is via scanning... LS1M, areoforce, HPT, anything to scan. The wideband will help as well, as you could actually communicate problems clearly without people having to guess.
