404ci with 76mm and .81 a/r ???
Old Feb 23, 2010 | 03:29 PM
KILLER-LS1's Avatar
http://www.youtube.com/watch?v=GGvHxObI5lg
heres a video of the problem. the meter only reads to 16 but on the dyno its actually closer to 20:1 afr
you can see when i go WOT the afr goes back to normal. it does this with or without the turbo being connected....
you can hear the motor kinda "chugging"
Old Feb 23, 2010 | 05:38 PM
TT350's Avatar
If the gate was to small it would over boost @ WOT.
It's in the tune.
Old Feb 23, 2010 | 08:36 PM
eviltwin_1987's Avatar
how can you continue to drive it if you think i sounds like its going to blow up?
Old Feb 23, 2010 | 08:44 PM
Dracer91's Avatar
I have a 347 with a front mount gt66 and .81a/r. Everyone told me it was to small too. . . after a 10.78 came up on the boards out of a stock engine they changed their minds. What kind of fuel pressure regulator are you using? I agree it has to be in the tune and not the turbo by watching your video. Depending on your regulator you can simulate the PE with fuel pressure.
Old Feb 23, 2010 | 09:04 PM
Rickys S/C Z28's Avatar
man i would bet 100 bucks that its in your tune i would go to a great shop or order a tune from some one on here, also man STOP DRIVING YOUR CAR TILL ITS FIXED! you will blow it up the way it is right now 20:1 is ******* crazy
By Brett Foote | 2026-06-04 05:00:17
