Started my Custom Frontmount Turbo...
The turbo is still the TC76 that I used to run, but the turbine housing is going from a .81AR to a 1.15AR. The turbo is going on the passenger side, where the battery used to be. I'm using the stock drivers side manifold and building the passenger side manifold myself with my buddy. Crossover pipe goes behind the trans and up and is 2.5". Downpipe is 3" and is stainless to the firewall, then aluminum from there out the back. Wastegate will be dumped out the front.
Here's a couple pics of what we've done today. You can see where the turbo will sit and what we've got started with the manifold. We may have the manifold all tacked up tonight.
Should see quite a bit more power out of it this year with the new setup
Going from the 2.5" crush bent exhaust and .81 of the STS setup to the full mandrel bent 3" and 1.15 ought to make a big difference. And it's fun
Also going to a big fuel pump and full return setup with giant injectors for E85.
Thanks to my bud Ninja for the fab help!
