turbo with stock map sensor?
Old Mar 3, 2010 | 02:26 PM
awd-rwd racer's Avatar
Default turbo with stock map sensor?
i plan on running only 5-6 psi. do i need a 2 bar map sensor or is it ok to stay with the stocker from my 01 ls1 with my ls6 manifold...
if i have to change. does anyone know the 2bar i need? im going to be running speed density btw
Old Mar 3, 2010 | 03:00 PM
sujomatt's Avatar
I am running stock with SD at 10psi lol
Old Mar 3, 2010 | 04:27 PM
everything was able to be tuned ok? why does everyone say you need to run a 2bar then?
Old Mar 3, 2010 | 05:12 PM
sujomatt's Avatar
Honestly I am not sure - I am assuming there are some limitations. But as far as I can tell, I have not run into them.
Old Mar 3, 2010 | 05:44 PM
speedcrazy2's Avatar
its hard to explain(without u seeing the maps in a tuner program) but basically any time you are under boost all of your fueling is coming from one line in your table with the stock map
so you cant fine tune every point throughout boost
with the 2bar you can map out every single point and it provides a much more accurate tune
a map sensor is only like 40 bucks so to me it is well worth it but i guess you do need a custom operating system also which if you are paying a tuner anyway it shouldnt be an issue
Old Mar 3, 2010 | 05:50 PM
crf538's Avatar
running speed density with a 1 bar seems like a recipe for disaster for sure, im assuming you just worked the last row of VE till your afr came in line?
There are a fair amount of blower cars running mass air with a 1 bar and just using the MAF for boost tuning , Ive dont a few procharger cars like this, but only 6 pound kits and i wouldnt do this with a turbo, only running 5-6 psi prolly wont last long either if your like the rest of us.
In my opinion its best to just do it right and go 2 bar sd straight off, the sensor you need is off a cobalt ss if i remeber right, its pretty to find the p/n on here
Old Mar 3, 2010 | 06:58 PM
sujomatt's Avatar
the question then arises - where to get one??
Old Mar 3, 2010 | 07:07 PM
got mine from the local auto parts store do a search here and you will find the part number
 Michael S. Palmer
Old Mar 3, 2010 | 07:10 PM
sujomatt's Avatar
I don't mean to threadjack - but I have a 3-bar already .. can I use that??
Old Mar 3, 2010 | 07:17 PM
i dont think you can because of the ecm,not positive but i think only 2001 and 2002 models are capable of 3-bar
i know that a 98 cant run 3-bar but i believe it was 98-00 that cant,but im also not sure if you can use it but your table will still only read 2-bar or if the sensor wont work right alltogether(good question)but i dont think it will report right unless you ecm is capable of 3-bar
its crazy how you forget little things like that when you dont ever think of them,one of these guys that deal with it everyday will surely chime in here soon
Old Mar 7, 2010 | 03:31 PM
sparkwirez06's Avatar
http://www.turbols6.com/gallery/TYPHOON-LSX-TURBO/afp here's the 2 bar, get it at gm parts counter.
Old Mar 7, 2010 | 04:53 PM
CarsandWomen's Avatar
cobalt ss MAP, Delphi PN 09350899
Old Mar 8, 2010 | 08:26 AM
daws222000's Avatar
Default 3 bar
I dont mean to jack your thread but i have a fast 3 bar map can i use it on a 97 corvette? How much boost can you run with a 2 bar map, i want to run about 18psi through a turbo? I have a newer ecu but it has to be pinned what a pita, I hope i dont have to do that.
Old Dec 30, 2012 | 05:19 PM
JoshuaGrooms83's Avatar
i have a digup question on this, i recently got a GM 2 bar MAP sensor and was wondering if i can run the car without tuning the car for the 2 bar map, until i get it tuned of course? i have a 98 TA with stock PCM, tuned by frost already for current mods.
Old Dec 30, 2012 | 06:29 PM
got-a-ls1's Avatar
nope you need a tune to run it
Old Mar 2, 2013 | 12:20 PM
damn, so in order to get ti tot he shop, leave in the stock snesor, and then switch it out when i get there lol? its literally a 5 minute drive down the road from my house. thats gonna suck. getting that damn sensor is such a PITA
