rear gear question with turbo
Old Mar 5, 2010 | 05:23 PM
Tzion_ben_Arthur's Avatar
Default rear gear question with turbo
Is anyone running a 4.11 with a 28 1/2 inch tire and turbo auto trans car? I have 4.11 in a 12 bolt right now and some 3.73 on the side. we have a 28 inch tire with th350 and 3500 converter with TB. We were going to make a few runs at 9 PSI with this gear to see where we are at. What can expect?
Old Mar 6, 2010 | 09:31 AM
Blownz28man's Avatar
I think it may be to much gear. I'm in the same boat. I'd say guess on your 1/4 time and speed. Then locate an RPM calculator and see what your RPM going through the traps. I'll be running a LS1 4l60e and 3.25 gears. But I wanted a good top end speed and enough to get the turbo spooling.
Old Mar 6, 2010 | 03:56 PM
Ya.. it shows 7000 at 141 mph. With an auto I bet this will be more like 7200. I will put the 3.73s in. I hate messing with that.
Old Mar 6, 2010 | 04:08 PM
ZL1Killa's Avatar
i would think with a turbo, you would want less of a gear than even what you are talking about
