Supercharger for 385
Old Dec 30, 2003 | 11:01 AM
z28hokie's Avatar
Default Supercharger for 385
Was wondering which supercharger to use for a 385, I want to run around 7psi, nothing much.
Was looking at the ATI/Procharger 5/7psi kit. But wasn't sure if that unit would be a appropriate for a stroked motor.
Old Dec 30, 2003 | 11:36 AM
Crunch's Avatar
Well, I'm biased towards Vortech.
If you put the V9 G-trim on that stoker motor, and swapped to the smaller pulley, I think you'd be practically unbeatable on the street with slicks.
If it is going on your Z-28, you will have to get someone to trim the underside of the hood. The T/A would not require hood modifications.
Old Dec 30, 2003 | 06:29 PM
tbyrne's Avatar
The Vortech with a smaller pulley would work good or you could go with the ATI D-1SC. I'd consider this to be a better choice for a stroker motor. When you order the kit you'll have to not your current mods and the boost level that you;d like to run so the system (ATI) can be built with the correct pulley. A smaller pulley would have to be purchased seperate for the Vortech kit.
Tom
