91mm t4 finally home
New:
Turbo
Flange
x
x
x
x
Flange
Flange
Old:
Turbo
Flange
Just a thought
Rick
Can't raise the turbo any because of the stock water pump yep. There is just enough room for the turbo blanket to fit in between
The grey is a 2000* paint to fight rust. nothing fancy (going under a blanket anyways)
The elbow is not from a sponsor, I had to look long and hard to find one, and its ribbed on the outside to fight collapsing.
The turbo feels like it weighs much more than the pt-88 thats all I know.
Still running 96# injectors. I will be watching the fuel system closely this season and upgrading what needs upgraded on the fly.
I am very relieved..I was losing sleep at night over having to drop 400 bux on some fans that may not be reliable or cool as well as the stockers, hack up the wiring, lose one of my fan speeds et. In the end it worked out so great and a friend basically gave the fans away to me.
As you see I had to fight quite hard for very little real estate but the difference is working vs. not working.
Anyways I think it came out right
it fits better than stock! I am using the thicker lt1 radiator.
So yea other than the fuel system I'm pretty much all set for this year (other than still need my trans back!) that and i'm going from a rule 1500 to a 2000 in the water tank.
Thanks very much. Hopefully I can get a new best again one of these years doin all this mumbo jumbo..
The core of his kit is still TTI. He's actually had TTI update his turbo up-pipe that he created so it's now their shared part. That was the biggest change really to get the PT88 turbine to fit below the stock T-stat housing and water pump and clear the passenger side steering gear.
The only other real changes are the move to the larger plastic 5 gal water tank behind the driver's seat (replaces the 1.5 gal battery tank) and a second update to the water pump move more water from the new tank. Then it's just a larger filter and 90 degree bend for the new Compressor 5" inlet. The rest is still original hot and cold pipe.
As another TTI Race Kit owner... I'd say it's still TTI kit from my perspective. It's just smart space appropriate shoe horning of enhancements.
Rick
Impressive work as usual David. Clean form and function. You really ought to think about making turbo kits...
