PCV check valve help?
Old Mar 8, 2010 | 06:16 PM
rickjamesCC's Avatar
Default PCV check valve help?
I have a turbo kit on a 2006 5.3 and it is a front mount. I original had filters on both valve covers for the crankcase venting but I did not feel comfortable with it so I ran passenger side to fresh air via air filter inlet of turbo and the passenger side I believe needs a one way valve such as the on APS uses on there kits to keep from boosting crankcase and I also don't understand why they say to drill the orifice in the valve cover to 1/4", and also where do you get the check valve?
Old Mar 8, 2010 | 10:53 PM
SKINNY69's Avatar
Check valves off of an Evo VIII are great to use if you're using rubber vacuum lines. I think they run around $15 at auto part stores.
Old Mar 9, 2010 | 06:59 AM
JAX04's Avatar
link??
Old Mar 9, 2010 | 10:03 AM
SKINNY69's Avatar
Originally Posted by JAX04
link??
Here's a picture of what I'm talking about. A quick google search should yield a website where you can pick them up. I've used them on my non GM turbo builds and they work like a charm.
Old Mar 9, 2010 | 10:15 AM
MUSTANGBRKR02's Avatar
these are what he is talking about. http://www.boombaracing.com/cv.html
