someone please help(att. rob raymer)
Old Jan 1, 2004 | 03:29 PM
squirrel masta's Avatar
From: its as intense as the time i forgot how to sit down
Default someone please help(att. rob raymer)
i am installing my qpm turbo kit and i am at the stage for the fuel pump ana i am puzzled on the install,i have the pump and sender out of the car and have it diisassembled but i dont want to wreck any hoses for the original incase this one is the wrong one,my car is an 02 firehawk any info would be great
Old Jan 1, 2004 | 04:11 PM
smokinHawk's Avatar
not sure what your question is?
but if your talking about the semi clear flexable hose, disconnect that from the sender unit, then install your new hose with clamps, it would help to double clamp them really tight so it doesnt blow off.
Old Jan 1, 2004 | 05:28 PM
well the question is the little hose that comes off the original pump the fiiting cant be removed and the bottom of the new pump is a little different.its the whole plastic sender type of pump
Old Jan 1, 2004 | 10:08 PM
smokinHawk's Avatar
there is the feed hose from the pump which is heated on, you might need to heat it to remove it, then that small vent hose (or something like that) you dont need that hose.
Old Jan 1, 2004 | 11:18 PM
ok i just had to cut the hose off and drilled a few holes in the bottom ,but now relized that i shold have cut out the black fuel inlet on the bottom of the sender cause the filter is kind of bunched up in there but o well ill pull the tank again on another day,thanx, smokin hawk
