World's fastest Ebay Kit!
Old Mar 19, 2010 | 09:47 PM
z28boysteve's Avatar
Default World's fastest Ebay Kit!
Actually I completely modified an original PTK kit as shown below to utilize a PT101 and 5" downpipe with 4" charge pipes to an interior mounted PT3000
The headers, and two crossover pipes are just as they came from PTK however (same as the Ebay kit but steel instead of stainless) The merge collector I removed the 38MM wastegate pipe from and mounted a 2 1/2 " stainless 90 to a Tial 60 and I removed and cut back the T4 flange and mounted a 3 1/2" stainless 90 to a T6 flange for the 101, The dowpipe is Home made 5" mandrel bent Stainless and the Charge pipes are home made from 4" aluminum mandrel bends.
This took 4 days of work and $900 in materials between silicone, clamps, and tubes.
However this turbo kit will support 1500 rwhp Im guessing.
Old Mar 19, 2010 | 09:53 PM
sorry fellas fixed the pics.
Old Mar 19, 2010 | 09:56 PM
HUNTER02SS's Avatar
That looks great. The only problem I see is the exhaust dumping and aiming to the front tire. That can cause for a bad day if that tire overheats and blow out.
Congrat's on the build , you did a great job!
Old Mar 19, 2010 | 10:00 PM
Well I figure I hope I dont see more than 8 seconds of full throttle at a time ever ;-) and it will be drag only this time around so hopefully the tire thing will be cool, I've done it before and was okay.
This whole build I started on tuesday when my pipes showed up and tada! lol.
Old Mar 20, 2010 | 08:36 AM
98Z28CobraKiller's Avatar
Restricted User
If the seal on that turbo lets go, that front tire will get oiled down. At 160+ MPH, that's not a good thing.
Looks great otherwise.
Old Mar 20, 2010 | 10:40 AM
SincalT/A's Avatar
You should point it towards the back for "Turbo Boost!!!".**** it worked for Knight Rider.
Really though it jus looks like potential problem.lm gonna go out on a limb and say last time you ran it like the car was not on the same level of hp.
Old Mar 20, 2010 | 10:57 AM
ninetres's Avatar
Are you suggesting a rear mount? LOTS of the frontmount cars have a turbo mounted on the side of an engine bay.......same with twins!
Old Mar 20, 2010 | 11:06 AM
jamnut's Avatar
I think they are talking about the turbo seal going out & oiling down the front tire through the DP.
I'm with the rest of the crew, looks great, but DP placement could be better. Good reason to run it through your front fender.
Old Mar 20, 2010 | 08:05 PM
Restricted User
Exactly.
Definetly nothing wrong with a front mount. I have one and it runs GOOD!
Old Mar 20, 2010 | 08:26 PM
who_needs_maf?'s Avatar
nice work that's awesome
Old Mar 20, 2010 | 08:39 PM
Shawn @ VA Speed's Avatar
maybe i didn't see it,what does the turbo mount to other than the piping?
and i agree 1000%,down pipe should not point at the tire,should exit the car far enough that any fluid would be out past the tire track
Old Mar 21, 2010 | 12:21 AM
craig382ci's Avatar
Where did you get the 5" pipe for the dp?
Old Mar 21, 2010 | 09:09 AM
Oh I didn't think the oil thing through
maybe I'll revise the downpipe later
I bought the stainless all from stainless
works I cost me 300 and I still got 3 foot of straight left over !
Old Mar 21, 2010 | 09:11 AM
works I cost me 300 and I still got 3 foot of straight left over ! And the turbo will be mounting up to the drivers cylinder head u just hadn't built the mount yet I'm a little sick of favrication at the moment lol
Old Mar 23, 2010 | 03:17 AM
chuntington101's Avatar
very nice setup mate! should make the power you are after!
Old Mar 23, 2010 | 07:12 AM
98Camarod's Avatar
Potentially the fastest.....mine drives right now
I thought about doing something like this, but I didn't like the idea that the turbo wouldn't have an air filter. I suppose you could have put in more in the center to allow for it. I think I'll just be doing the truck manifolds though.
Old Mar 23, 2010 | 08:18 PM
OUTLAWZ RACING's Avatar
Lmfao!!!!
Old Mar 24, 2010 | 02:18 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Want to pass any details along about the engine powering it?
Old Mar 24, 2010 | 04:40 PM
402 lq9 with the dreaded ls3 heads (until I get masts and o-ringing and semi block fill) gmhp single plane and Wilson elbow with 105 mm ford tb just simple stuff for now to get the job done all forged with diamonds and 8.3:1
Old Mar 24, 2010 | 04:52 PM
98Camarod's Avatar
^^thats a really low CR
