Turbo noise?
Old Mar 29, 2010 | 10:28 PM
2ktransam's Avatar
Default Turbo noise?
I have a tc76 BB turbo and it is making a weird noise. It has about 10k miles on it and it is out of warrenty. The turbo is on a STS kit with a 1.15ar exhaust housing and seems to boost fine and makes great power. At idle the turbo doesn't free spin anymore and it makes a squealing noise when it comes to a stop. It's been doing this for a little while but the performance of the turbo hasn't changed other than the noise when it comes to a stop. How bad is this? How much is a rebuild on a BB unit if it needs it? Thanks
Old Mar 30, 2010 | 08:53 AM
CarsandWomen's Avatar
one might suggest you call T-netics and ask, its not like theyre going to void your warranty
Old Mar 30, 2010 | 04:29 PM
Snyper's Avatar
Sounds like the bearings are shot. And BB rebuilds cost almost as much as new turbos.
Old Mar 30, 2010 | 04:33 PM
XtremeDime's Avatar
My MP t70 is doing that too. MP is sending me a new turbo on warranty
Old Mar 30, 2010 | 04:51 PM
lt170chevelle's Avatar
yeah definitely sounds like a bunch of slack in the center section caused by worn bearings allowing the turbine to contact the housing .. ...worst part about it is if its been going on for a while its probally worn the impeller and turbine..but if you keep spoolin it up it will get so much clearance from that it wont make boost.
Old Mar 30, 2010 | 05:51 PM
2ktransam's Avatar
That's what I'm afraid of but I didn't think that ball bearings would ware out this fast. How much is it to rebuild a ball bearing turbo? I have a hard time believing it cost as much as a new turbo.
By Brett Foote | 2026-06-04 05:00:17
