Oil cooler location?
Old Jan 5, 2004 | 08:16 AM
Turbo 1LE's Avatar
Question Oil cooler location?
Hi everone
I have a 99 1LE with a built motor and a single turbo set-up. I was thinking of installing a oil cooler after the Turbo just to get the temp. of the oil down. The Problem is the Turbo takes up all the room on the driverside and the blow-off valve takes up most of the room on the right.The innercooler takes up the grill area Help............................ Any idea of an area I can mount one and still have good airflow?
Old Jan 5, 2004 | 09:14 AM
smokinHawk's Avatar
if you make a air dam you could position it almost anywhere you want on the bottom of your engine bay.
the only thing now i could be concered about you will have to run a scavenge pump since your drain wont work by gravity any more.
it would be good though to cool the oil , mine gets black fast with the turbo.
