How good/bad is my WG position
Old Apr 12, 2010 | 08:11 PM
91sbcamaro's Avatar
Default How good/bad is my WG position
Take a look at the picture and let me know what you think. I didn't to do a straight 90* off the merge as that wouldn't flow very well. This is what I came up with and I just want some opinions. It seemed like the best/available place to do it.
The black is going to be a second pipe merging into the one already placed in the other side. The red outline is where the WG flange will be welded.
Old Apr 12, 2010 | 08:35 PM
reamo04's Avatar
try to get it so the pipe isnt coming off perpendicular to the bend. angle it so the red part is closer to the turbo flange.
Old Apr 12, 2010 | 08:40 PM
HydroStream6's Avatar
I've seen setups with the wg coming off at almost a 90* angle, with no issues. While getting closer to tangent would flow better, it should still work fine.
Old Apr 12, 2010 | 09:19 PM
Josh@PremierAutosports's Avatar
I'm sure it will work just fine. What size motor, turbo, and wastegate? Unless you are running a 38mm I fell you are ok.
Old Apr 12, 2010 | 11:01 PM
91sbcamaro's Avatar
Pretty much stock LS1, MP T76 and I'm going to run a 40mm JGS WG
Old Apr 13, 2010 | 09:24 AM
You will be fine.
Old Apr 13, 2010 | 12:25 PM
crf538's Avatar
yeah it'll be fine, i had a tc76 on a stock ls1 and it would hold 10 psi with a 38mm wastegate. i had a single 1 3/4" pipe at a 90 degree angle to flow going to the wastegate.
