I need Fuel Advice for Procharger..
Old Apr 20, 2010 | 01:55 PM
fatmat80's Avatar
Default I need Fuel Advice for Procharger..
Procharger guys i am putting together my fuel system for my Forged 347 D1sc build..I have read a lot of things on this forumn but am still a little confused..What is needed to support a 700 hp motor with room to grow in the future?
So far i have:
60 lb injectors
dual walbros
I think i need:
hobbs switch
fuel rails
adjustable fuel regulator
hot wire kit
some 6 an fuel line
hose clamps..
Please post up with your fuel parts lists and hopefully where or who you ordered from..Any install threads would be helpful as well...
Thanks in Advance..
Old Apr 20, 2010 | 02:50 PM
Eagle02's Avatar
Here's a link to size your injectors:
http://www.witchhunter.com/injectorcalc1.php4
Looks like your injectors are already too small. I recently took on the same challenge you're looking at right there and ended up buying a kit off Nasty Performance to solve my problem. The kit I got provided everything required to run ~1000WHP.
-8feed
-6return
2 pumps set in my now customized sending unit
a very awesomely constructed harness that was completely plug and play
Aeromotive rails & FPR
All required Earls fittings
80lb injectors...
I'm sure I missed some stuff... but you get the idea. More on the stage 3 setup here:
http://www.nastyperformance.com/CustomFuelSystems.html
Old Apr 20, 2010 | 03:24 PM
LS1RedZ's Avatar
^^ What he said...
I am running the Nasty Stage 3 system on my car. My car made 754rwhp and still has alot of room. The dual walbro setups have supported 900+ to the wheels. Looks like you have a good idea of what you need.
Nasty N8's Avatar
Thanks Man! Ya feel free to give me a call I will help you get the correct setup for your needs.
Old Apr 20, 2010 | 09:59 PM
fatmat80's Avatar
Thanks for your help so far i will call Nasty Performance in the coming days..Please keep the info coming..
