Blown Head Gasket
Old Apr 29, 2010 | 09:55 AM
SuperC1's Avatar
lower the compression. Any power lost will be minimal, and the safety it will offer for more boost will be massive.
Yea, going with the 317's will help drop it down to 10.1, that's as low as I can go without changing the pistons. I'm looking forward to getting this thing back on the road again, that last pass was a ****.
Old Apr 30, 2010 | 08:50 PM
SuperC1's Avatar
Got the head off the side that was leaking antifreeze, and what do you know, the steel gasket burned through, along with a chunk of the block, take a look.
Attached Thumbnails Blown Head Gasket-boost-002.jpg   Blown Head Gasket-boost-003.jpg   Blown Head Gasket-boost-004.jpg
Old Apr 30, 2010 | 08:59 PM
ss.slp.ls1's Avatar
Wow!!! I have never seen that happen before...
Old Apr 30, 2010 | 09:42 PM
Zombie's Avatar
Time for a rebuild... bummer.
Old Apr 30, 2010 | 10:28 PM
1_bad94Camaro's Avatar
damn bro. thats a nice crack in that block.
Old May 1, 2010 | 01:18 AM
sschoeffler's Avatar
Nothing a little super glue wont fix
Old May 1, 2010 | 06:20 AM
stevieturbo's Avatar
I have, I did it about 18 months ago.....except it took my cylinder head out too !!!!
In fact...blew a hole through the block/head surface. All the valves were overheated and deformed, and all the pistons fucked.
Total destruction really.
That engine is scrap. I'd imagine your pistons are all destroyed too.
Lean mixtures, too much timing.....whatwever. Either way it has been massive detonation that has caused it.
Old May 1, 2010 | 07:03 AM
SuperC1's Avatar
Actually the pistons looked good except for the one with the chipped ring land, all the other ones looked fine. What surprises me is the head surface cracked, but the piston didn't. I assume the aluminum block has it weak points. I may go back with iron this time.
Old May 1, 2010 | 09:00 AM
Until you have removed the pistons, you cannot tell if they are good or not.
Old May 1, 2010 | 09:02 AM
Something I'm also curious about.....which cylinder is that ? Mine did no 6 with the plasma torch.
https://ls1tech.com/forums/forced-in...d-biggest.html
Old May 1, 2010 | 10:25 AM
SuperC1's Avatar
That was number one with the chip and the block cracked around the number three.
Old May 1, 2010 | 01:00 PM
  #32
kikass_z28's Avatar
wow bummer
Old May 1, 2010 | 01:10 PM
  #33
WS6HUMMER's Avatar
Man that sucks, sorry to see this happen.
Old May 1, 2010 | 01:12 PM
  #34
forcd ind's Avatar
dam, that was one angry motor-bummer it did so much damage
the ox content in gas is so high now, or whatever they do to it, i just add some 110 if im gonna make some passes anymore, just use pump gas on the street
Old May 1, 2010 | 03:14 PM
  #35
SuperC1's Avatar
I agree, I think I'll go with an iron 408 this time.
Old May 1, 2010 | 03:23 PM
  #36
Either way, the damage is tuning related.
Old May 1, 2010 | 03:39 PM
  #37
SuperC1's Avatar
Yes it is, I agree, it was not tuned to run over 14 lbs of boost. It would have lived forever if it wasn't for that. This was all user error, not fault on the engine at all.
Old May 1, 2010 | 03:59 PM
  #38
I was just saying that iron or alloy...there would still have been serious damage. Although of course the iron is the stronger platform.
I also doubt its the limit of pump gas. Perhaps with the high CR it is, but more power will be safely achievable on pump, with a lower CR.
There are little 2.0 4pots making 800bhp on pump gas, so a 6.0+ V8 with a bit of boost shouldnt struggle to do similar.
Old May 1, 2010 | 05:08 PM
  #39
Zombie's Avatar
Smaller cylinder bores are less prone to detonation, that's why they can run more boost on less oct. My 8.7:1 is limited to 14psi on 91 oct where as a Evo can run 20-25 psi on the same fuel and I see it done all the time.
Old May 1, 2010 | 05:15 PM
  #40
Subaru's 99.5mm bore of the 2.5 can easily handle 30psi on pump fuel with mid 8's CR
Which is basically a 4.0" bore, albeit with very short stroke.
My LS is safely running 20psi on 9.5:1 CR on equivalent to 93 octane, albeit with a centri.
A CR of 8.7:1 would easily handle 20psi no problem at all IMO.
