lq4 or ls1 d1sc build?
Old May 9, 2010 | 07:41 PM
Ls1manSS's Avatar
Default lq4 or ls1 d1sc build?
ok im wanting to build a procharged ls based motor and i want to get some ideas together to see which one is better.. im trying to decide between lq4 and ls1 with cam and full bolt ons.. i know lq4 can run a little more boost because of the compression but can it hold a good 10lbs psi with apr rod bolts? or is the ls1 with 8lbs and arp rod bolts more durable and more powerfull even tho its a 5.7 and not a 6.0? my car does have a moser 12 bolt and axels and built t56 so drivetrain is not an issue, but give me your opinions on whats more durable and powerfull, i would even go with a turbo if i find a kit, but thanks for the help..
