Methanol plate kit?
Old May 11, 2010 | 06:34 AM
chuntington101's Avatar
i think a meth plate kit would be great! Say 8 very fine nozels that follwed the same as a M5 nozzel. You could even machine the plate with 2 feeds. Then have 4 on one M5 equivient feed and a second set of 4 for the 2nd feed. I'm sure you would end up with a much finer mist of meth and that should help further with cooling. Also with a finer mist you should vapourise the meth quicker (thanks to a greater surface area) and therefore you could mount to meth 'plate' closer to the throttle body......
Also the hard work has already been done with the N2O guys.surely this should be a simple task?......
Chris.
Old May 13, 2010 | 07:50 PM
Julio's Avatar
On a plate kit what breaks up the fuel is a 1000 PSI nitrous bottle. You cannot get enough pressure from a meth pump to = 1000 PSI bottle.
Notice how nitrous nozzles are nitrous only or nitrous fuel. There is no "fuel" nozzle.
Dont know why someone who's never used a meth system doesnt start with a simple system then complicates it latter as needed. Get your nozzle sizing wrong, dribble out of the nozzle pre-compressor and whalla..you get to buy a new SC/Turbo when the droplets kill the blade.
