Anyone been lifting heads?
Old Jan 12, 2004 | 04:40 PM
Slowhawk's Avatar
LS1Tech Sponsor
From what I gather,Turbo's should be tuned for 11-1 or lower for the street.My GN is tuned for 12-1.. 12.5-1 is really pushing it when it's loaded on the street.
Old Jan 12, 2004 | 05:10 PM
Rob Raymer's Avatar
In my opinion, 12.5:1 on the dyno is way lean. That would be about 13.5:1 or leaner on the street.
We tune for 11.0-11.5:1 on the dyno, with 11.8:1 being the leanest we would ever let leave the shop. And that would only be if the person planned on running race gas.
My guess would be that the 104 octane fuel you are running is the only thing saving you right now.
Just my opinion though.
Old Jan 12, 2004 | 07:15 PM
NA$TY-TA's Avatar
Rob what do you have to say about lifting heads and which gaskets should be ran and if we should O-ring the heads and all.???
Old Jan 12, 2004 | 07:32 PM
Vents's Avatar
i lifted up a set today
Old Jan 12, 2004 | 07:58 PM
GueSS Who's Avatar
I agree with Rob. I do think you are on the far edge. If you do the o-ringing of the heads the best way is to have a receiver groove cut into the block. I don't think you could blow a gsk that way. It would be really hard IMO.
Old Jan 12, 2004 | 11:25 PM
Jammer's Avatar
The replies are great and interesting. What I am seeing is not many have had head lifting issues, and when they did it was likely the tune as it pertains to the way it was...well...driven.
I'll add a follow up question...if thew heads are ringed, and the block isnt...is that really gaining much? This should be addressed and expl;ained. Brian? You out there? Rob, you have experience with O-ringed Judson TEAs if I remember right... chime in...
Old Jan 12, 2004 | 11:35 PM
Whistler's Avatar
Sawzall and Welder Mod
I dont think you can O ring the block on an alloy block LS1.
Old Jan 13, 2004 | 10:09 AM
NA$TY-TA's Avatar
Im asking what the same thing JMJ is asking. Im not sure about O-ringing the block on an aluminum block. I know Rob has his heads for his new project car O-ringed. I believe hes using TEA heads, but i would like to know what or who's rings and and what head gaskets hes using. In the beginning i was thinking about just using 6.0L MLS head gaskets and using head studs. I will be coged also shooting for 16 psi.
Kyle
 Michael S. Palmer
Old Jan 13, 2004 | 10:43 AM
Shinobi'sZ's Avatar
I have not run 16lbs of boost on the street yet..it requires that I turn on my boost controller. Yes that is with 104 Sunoco and I would never attempt that boost with anything but straight 104 or Turbo Blue.
Yes your opinion definetly counts.
What I was told and you guys correct me if its wrong...is that if the fuel tables are zero'd out..then there is not much of a difference at all on the dyno vs. the street. Rob or PSJ are you buying that????? When you guys tune are you getting your Fuel Trims zero'd out???
Thanks
Old Jan 13, 2004 | 12:13 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
All the folks I have talked to who run 700-1000 hp setups suggest the numbers that Rob posted. You will run a full point more lean on the street is what everybody said. I'm including tuners of low 9 second Supras and 8 and 9 second Mustangs.
Old Jan 13, 2004 | 12:16 PM
y2khawk's Avatar
Not when you use a real dyno
12:1 on the dyno, and 12:1 on the street for me. Same WB in the car for street and dyno.
I've been using MLS gaskets and studs with great results. Not lifting, no cooling system pressure.
Old Jan 13, 2004 | 12:28 PM
  #32
onfire's Avatar
Coal Mining Director
Shinobi, it depends which dyno you used. The table being zero'd out doesn't change the fact that a DynoJet dyno does not load the engine like a wot street run. If you used a Mustang dyno you're ok but could use a little more fuel. If it was a Dynojet, then you're way too lean on the street.
Old Jan 13, 2004 | 12:33 PM
  #33
Shinobi'sZ's Avatar
Yes it was a dyno jet 248. We are going to run EFI Live or a Tech II and take the car out for a spin. We should be able to pick up any detonation. I was told that if the dyno was right and the tables were Zero'd out that it would not make a difference. Argumentively though I have seen dyno graphs of LPE cars that show them at 13.1 on a 248 Dynojet.
I run 91 octane and 11lbs of boost on the street. The AFR was supposed to be 10.5:1 but I think I hear detonation. I have been told that the internal wastegates are very loud and make a quick series of tapping sounds..I want to just verify that it is not detonation.
Thanks
Old Jan 13, 2004 | 12:55 PM
  #34
LS1Tech Co-Founder
For the record if you have audible detonation in a FI car you are on the slippery slope.
Someone might pull their car on a Dynojet 248 at 12.5-13.1 PSI but the racers will back the tune off to make it safe.
I personally talked to like 10 different tuners on this issue and they were all the same, 11-1 to 11.5:1 on the dyno at WOT.
Old Jan 13, 2004 | 03:57 PM
  #35
Shinobi'sZ's Avatar
I have been through a couple of LS1 and LS6 Motors...so I am familar with detonation.
So whats a RACER????
Seriously I appreciate the information. This is why I will go out on the street and verify if I am getting detonation with a Tech II or EFIv6. If I am not I know everything is cool...if I am than I will find a way to fix it. I have to put in a new clutch anyway...my clutch won't even hold the peak power my setup made on the dyno let alone with a load on it....wished they would have had a loader on the Dynojet like they have with a Mustang Dyno.
I just double checked my Air/Fuel for both boost runs.
The AFR on the 11-12.5lbs of boost run, using 91 Octane was 11.2.
The AFR on the 14-16.5lbs of boost run (boost controller on), using Sunoco 104 Octane was 12.7.
Old Jan 13, 2004 | 05:33 PM
  #36
onfire's Avatar
Looks like you're safe at 11psi....not safe at 14psi.
FWIW I've seen 2 LPE TT Dynojet dynographs....both where 11.4 to 11.6 AF.
Somethings wrong with the LPE 13:1 TT Dynojet.....could it have been NA?
Old Jan 13, 2004 | 11:43 PM
  #37
Jammer's Avatar
Not to start a fire, but I saw/have an A/F from one of the "Major" NJ Tuners that gets into the 13's at upper RPM/s at WOT. Same car saw 3k+miles and over 50 1320's this season with that tune. I would not do it myself, just stating one mans "situation".
If I remember right, Rob used stock GM gaskets (graphite?) on his "old, now sold" car.
Where is that car anyway....did a forum member buy it?
Y2K, you always give me hope...MLS..no orings...love it.
I guess I'll go that route and w/ some of those special $375 ARP head studs from Dave White.... at least thats todays vision...I dont see too clearly though....
Old Jan 14, 2004 | 10:16 AM
  #38
Shinobi'sZ's Avatar
I am only 12.7 Air/Fuel at 16.5lbs of boost.....but I am using 104 so detonation is not present.
I am using no 0 Ring Heads and Stock 2002 MLS Gaskets too.
Old Jan 14, 2004 | 11:24 AM
  #39
CHRISPY's Avatar
Richen it up to 11-11.5:1 on a dynojet especially if you are turbo.
Blower cars are not load dependant so you can go a little leaner. I would still never go above 12.2:1 on a dynojet though with a supercharger.
You want a little cushion regardless.
Chris
Old Jan 14, 2004 | 01:50 PM
  #40
ChevyNo1's Avatar
#'s in my sig were exactly what Chris and John say, 11-11.5:1 on dynojet. Seems to be giving me decent enuff power! And this Saturday 918's are replacing the weak stockers, look for that HP to jump up close to 630
- Dug
