head gaskets?
Old May 24, 2010 | 02:32 PM
Ryan Armstrong's Avatar
Default head gaskets?
What is the best head gasket for a turbo car.
i'm building a 5.3 with 317 heads and a T76. I'm trying for 15-18 psi.
Thanks,
Ryan
Old May 24, 2010 | 02:41 PM
ss.slp.ls1's Avatar
Pick up some LS9 head gaskets from SDPC.
Old May 24, 2010 | 07:33 PM
conan's Avatar
Have you had the block decks and heads shaved to make sure they are straight ? If so cometic MLS are a good choice, but they do require a good surface to seal. GM MLS gaskets for the 6.0L will get the job done too. Just make sure you stud the heads with what ever gasket you choose.
