will this cam work
Old May 31, 2010 | 08:25 PM
charged 434's Avatar
Default will this cam work
i am building a 427 with the lsx block. beck sheetmetal intake, 96 mm TB, mast large bore ls3/l92 head they flowed 378 @ 650 lift. i am going to drive the car more than race. oh and i have a f1-c going on it. the cam that i have is this
Lc 114 intake c/l 110, exh c/l 118
int opens 16.5BTDC, int closes56.5 ABC
exh opens 67.5 BBC, exh closes 11.5 ATDC
intake 253 @50 net lift 612
exh 259 @50 lift 612
can i run this or do i need to regrind it
Old May 31, 2010 | 11:23 PM
98Z28CobraKiller's Avatar
Restricted User
You can run it but it's not ideal and pretty big for a mostly street car. What did the heads flow at .612?
Old Jun 1, 2010 | 12:15 AM
DeltaT's Avatar
It's a little big but the 434 will swallow it nicely. I have a 421 with a 250/256 on 115lsa solid roller so you are in the same ballpark.
Yours is going to lope more than mine since the solid roller is a little smaller after lash is taken into account - mine will run like a 244/250. I'd go for it and then swap if you don't like it. It will make big power all through the powerband.
Jim
