Turbo Cam?
Old Jun 1, 2010 | 03:59 PM
Zero4488's Avatar
Restricted User
Default Turbo Cam?
Need a good idea on what cams you guys are running? Looking for recommendations for a 346, 364, and a 408 ci setup. I was looking at the Speed Inc cams and really thinking about going with one of their cams....what do you guys think?
Old Jun 1, 2010 | 04:57 PM
BADBOB's Avatar
i asked the same ? on yellowbullet and everyone said virginia speed. they can custom make one or you can buy one of there 5 pre spec grinds
http://shop.virginiaspeed.com/catego...?categoryId=33
Old Jun 1, 2010 | 10:31 PM
ModularTurbo's Avatar
I ALWAYS recommend Vengeance Racing to my customers. Tell them Rob@modularturbo sent ya. They know their stuff period..... Ask for Ron.
Old Jun 1, 2010 | 11:16 PM
98Z28CobraKiller's Avatar
Restricted User
So you dont know what you are building but you want us to pick a cam for it? You need to pick your turbo or your cubes and build around it. Once you have turbo, cubes, intake and heads picked out, then you spec a cam.
Old Jun 2, 2010 | 12:00 AM
Zero4488's Avatar
Restricted User
First build is going to be a stout 346, 241 heads hogged out, a Super Victor and a 92mm tb, with a GT76 through a th400.....while that setup is together I will be putting together an iron block of either stock displacement of turn it into a 408. I was basically trying to gauge a cam for both setup's that will most likely work with both setups. The bigger motor will of course be getting a bigger turbo and a 265cc head combo to boot. I am open to suggestions and just want to know whats available. Not trying to have somebody else put my setup together just checking my options. Also any recommendations on what stall size to match up with the 346?
Old Jun 2, 2010 | 03:35 AM
So.jerZ-28's Avatar
dave..... the 346 vrs. the 408 w/ 265cc heads are 2 different animals.
the cam for the 408 will need to be quite different in specs due to that you'll need a cam that'll fill its cylinders.
call cammotion... they know their ****.
my $.02
346 turbo cam use: 224/220 580" to 595" range on lift 116+4
rob's converter won't work if that helps any!!! lol
Old Jun 2, 2010 | 09:04 AM
Zero4488's Avatar
Restricted User
No ****....lol
Old Jun 2, 2010 | 11:40 AM
jay_rich's Avatar
I went with the SpeedInc TU2, my motor isnt finished so I cant tell ya how it works lol. Its a big turbo cam but im aiming for the 800whp range.
236/236 .587/.587 112.5lsa
A guy on here from speedinc uses it in his grudge car.
Jay
Old Jun 2, 2010 | 01:02 PM
dreamls1's Avatar
Holla at Pat G.. he will get you a custom cam
