Boost jumping around normal or turbo fubared?
Its harder to check boost at full wot do to the speeds the car gets too and haven't got copilot to watch boost gage for me.
But when I put it into boost at say half throttle and hold throttle steady I am seeing like 4,2,3,4,2 type of think happening. I would think this is obviously showing the turbos are not working right. At least one of them .
This is on my stock aps turbos not my LG turbos. Lg turbos have not been installed but will be shortly. Just wanted to try to run the aps a bit longer.Course with two its hard to know if one or both is problem. I have not checked shaft play on them lately. checked a few months back and the drivers side was fine and never checked the passenger side but then wasn't noticing the surging. And not seeing any clouds of smoke yet either.
Gates open and close - depending on the size you may see a little movement up and down.
Need to check this at WOT and log it somehow. That will give you a better read on what is going on.
