Hobbs switch after bypass valve?
Old Jun 10, 2010 | 04:17 PM
Inspector12's Avatar
TT-TECH Veteran
Originally Posted by 427
The problem with my truck is the stock regulator was overun at low speed and idle when both pumps ran, so I had to run one only when driving normal. If you use the race type regulator both should work fine I would guess.
Kurt
Yeah you will have that using the stock regulators etc... Well you know LOL!
Old Jun 10, 2010 | 04:21 PM
ss.slp.ls1's Avatar
I see, so I guess I will be picking up a hobs switch. I will be using a '98 fuel pump assembly modified with dual walbro pumps in my '97 tank (LT1 car), LS1 fuel lines to the front to my LS3 fuel rail and 60# injectors.
Old Jun 10, 2010 | 07:16 PM
02NBMFormula's Avatar
Just be sure to monitor fuel pressure, my hobbs switch wouldnt turn on all the time, so i ended up bypassing it with a simple on/off switch. its crude but i know that it works
Old Jun 10, 2010 | 07:21 PM
ss.slp.ls1's Avatar
I have a fuel pressure gauge (not that I am sure to cautch a problem before it is too late). A switch is not a bad idea actually. I can leave one pump on for normal use, and switch on the second for when I hot dog it around. But I do like the idea of a hobs switch better. I could simply wire up a diode to it and have it light up when the switch closes so that I know it's on.
Old Jun 11, 2010 | 05:33 AM
TT-TECH Veteran
Yeah I know have a friend that still runs both all the time with the stock regulator and just tuned around it I just don't like having the spring on the stock regulator open all the time until you go under WOT etc...
