F1R install
Old Jan 15, 2004 | 05:45 AM
jasond26's Avatar
Default F1R install
Would this head unit be overkill for a 6.0 forged internals. I am getting some GTP stage II heads and already have a lingenfelter 220/220 566/566 lsa120 cam. I only have 50lb msd injectors though. Its 9.1 compression. Also does it bolt up to the existing bracket. I have plenty of room to mount, if it fits in the standard bracket. I want to push the motor as far as it will go.
Old Jan 15, 2004 | 06:45 AM
Reckless's Avatar
Super Moderator
I believe Ronnie Duke's 8.5-sec car uses and F1. His motor is a destroked big bore C5R block, and I think it's around 387cid?
Old Jan 15, 2004 | 08:48 AM
Jimmy98Z's Avatar
You might wanna try another cam if you do the F1R you need a split patteren cam.
Jimmy
Old Jan 15, 2004 | 09:20 AM
scottywheels's Avatar
split pattern cam and I believe the F1 would be fine for what you want. I have a F1 and all the innercoolers for sale with brackets and my custom 8 ib set up as well.. I made 600 rwhp with a built set up with 14 psi. The F1R would be a bit overkill.
