procharger guys what filter are you using????
Old Jul 31, 2010 | 01:54 PM
stngtamr29's Avatar
Originally Posted by conan
This is what I'm using, I saw a gain 1.5 #'s of boost.
Procharger supplied filter on the left new filer on the right. http://mycarpics.shutterfly.com/276
K/N # for big filter ^^^ http://www.knfilters.com/search/prod...x?Prod=RF-1045
Added this little filter for the bypass hole. I had a frost plug in that hole to start. http://mycarpics.shutterfly.com/277
K/N # for the small filter ^^^ http://www.knfilters.com/search/prod...x?Prod=RU-0200
Hey have you ever had problems with yours picking up water and was that some type of pvc elbow looks like 1 1/2 or 1 1/4 thanks j
Old Jul 31, 2010 | 03:35 PM
conan's Avatar
My car is a garage queen that is never driven in the rain, so no water problems here.
The elbo is a 1-1/2" pvc pipe and the rubber couplers all came from home depot. The 2 filters and the plumbing supplies cost me just under $100.
Old Jul 31, 2010 | 07:14 PM
mike135531bubba's Avatar
any problems getting the bigger filter to fit as opposed to the supplied one?
Old Jul 31, 2010 | 09:03 PM
LSXFORMULA99's Avatar
i run the 4in also. its a tight fit but work good
Old Jul 31, 2010 | 09:25 PM
conan's Avatar
It's a tight squeeze but with my air pump gone it's not too bad removing and reinstalling.
Old Jul 31, 2010 | 09:28 PM
blue00ZZleeper's Avatar
Unfortunatly I have had this problem. The car was ok cruising but if I ever came close to getting out of vacume it got pissed...quick lol...I dried the filter out and all was well. It was a really bad freak storm a while ago....I had to drive 40 as to not hydroplane lol. I've driven it in the rain since then...it hasn't happened again...I think it was the fact that there was A LOT of water on the roadway
Old Jul 31, 2010 | 09:45 PM
stngtamr29's Avatar
I think I might try this tomorrow because I recently had a cam installed and lost 2psi Thanks j
Old Jul 31, 2010 | 11:05 PM
No Juice's Avatar
Is that the same big filter that Bob used to sell at EPP?
Old Aug 1, 2010 | 07:02 AM
conan's Avatar
I think it's a little shorter, but the 5" base and 4" top was close to that one. I ordered the truck hat and the bigger filter from bob when he was at epp and I couldn't get either to fit with the twin intercooler plumbing. So after some reading in the FI section I decided to add the small filter and get the biggest one I could fit in the wheel well.
Old Aug 2, 2010 | 12:30 PM
MadIceV8's Avatar
Customizing Director
conan - Thanks for the information and model numbers. I'm going to order the larger filter and give it a try. Hopefully it helps out.
Old Aug 2, 2010 | 01:31 PM
conan's Avatar
No problem.
If your on the big red race by pass I would recomend the little filter on the hat too. My little filter gets just as dirty as the big one, so it's helping in the quest for air flow in to the head unit.
Old Aug 2, 2010 | 01:44 PM
  #32
MadIceV8's Avatar
No problem.
Also good to know. I'll do this when I upgrade my BPV.
Old Aug 2, 2010 | 01:57 PM
  #33
jetttstream's Avatar
Originally Posted by silver2010
I use this one on my 2010. K&N but not sure of part number.
Hello,
May I ask what kind of IAT's you see with this setup? I have considered something like this, but am seeing 20+ ambient with the filter in the engine bay and no airbox.
Old Aug 2, 2010 | 03:31 PM
  #34
SuperSport2000's Avatar
Does anyone have air filter inlet pics of a F1R?
Old Aug 2, 2010 | 05:02 PM
  #35
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Here is what we did on my Camaro. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Aug 2, 2010 | 05:04 PM
  #36
LS1Tech Sponsor
I have the filters listed at this link.
http://shop.brutespeed.com/ATI-ProCh...sories_c18.htm
Bob
__________________
Old Aug 2, 2010 | 05:06 PM
  #37
Thanks for the pic Bob. Do you have any problem with overheating on the street?
Old Aug 2, 2010 | 05:10 PM
  #38
LS1Tech Sponsor
It didn't get driven on the street much after we went to the narrower radiator. It should of been able to handle the 35 mile True Street cruise without a problem. I don't know how much the new owner has driven it this year, and I don't know if he gets on here at all. Bob
__________________
Old Aug 2, 2010 | 05:38 PM
  #39
danbap's Avatar
do you have a part number for the filter you ran on your camaro?
Old Aug 2, 2010 | 08:23 PM
  #40
thanks for the info and part numbers i'll try it out seeing as i also have the air pump removed
i'm currently running the stock pulley on the procharger and seeing 6 psi of boost. do you think my boost would change using the bigger filter?
