Custom cam for 408 76mm Turbo build
13018/3726HR116+2
Duration @ .050 231/232
Lift w/1.7 rockers .617/.595
LSA 116 degrees
Project is a 408ci, 76mm Garrett turbo with an 80mm compressor trim. (A/R .96)
Aiming to hit 1000 FWHP (Mostly driven on the street, but will see fair amount of track time)
15-20 psi boost
3500 lb car
9.3 Static Compression
TF 235cc heads
E85 fuel
3800 rpm stall
Single plane intake
3.70 9" Ford rear
Jim
Jim
When you put some timing in the right spot and get the mixtures correct...hell yeah, that will spool...probably out of breath by 6200rpm...
Thanks
Jeff
When you max out the turbo, you just wont make anymore power. Keep in mind that it will make the charge very hot which leads to detonation and ultimately failure.
