Meth vs nitrous on a roots
Old Jul 13, 2010 | 03:59 PM
3.8redbird's Avatar
Originally Posted by DeltaT
The Lysholm twinscrew is not derived from the Roots. They are a totally different animal. The twinscrews are air movers that actually have some internal compression while the Roots are simply air movers. That's what makes the twinscrews more efficient (a simplified description). You made a good choice.
Jim
Thanks for the clarification. By roots derived I meant how it mounts.
Ill look into plumbing a meth kit into the bottom of the KB
Old Jul 13, 2010 | 04:23 PM
Fast4a6's Avatar
Originally Posted by 3.8redbird
416/418. 9.3 cr all forged
Nitrous cools the temps and I have read meth on a roots doesnt do much.
It does work with the roots in cooling the air temps, but theres the factor of the pump failing which has happend before under a good amount of boost nitrous would be a safer way.
Old Jul 13, 2010 | 04:31 PM
3.8redbird's Avatar
Im thinking about building the block to handle the 20-23psi without meth or nitrous. 93oct. 8.5 cr.
Then have the nitrous and meth hit on the side. Nitrous cant engage unless the meth pump engages. Failsafe setup.
And I looked at the cost difference and an LSX block with 4.125 bore seems likely to handle the power better
Old Jul 14, 2010 | 03:48 PM
Julio's Avatar
Different animals all together.
Meth will only cool air going into the blower not coming out of it. Every PSi boost is approx 11 degree's. 10 PSI is 110 degree's above ambient. So if its 100 degree's and you run 10 PSI you have 210 coming out of the blower. If you shoot meth pre throttle, its temperature drops to 70 degree's and out let temps drops from 210 to 180. See where this is going. The bonus is if you run straight meth, you get the octane bump from running it. Like throwing 110 in your tank. this bump and how much depends on how much you spray. So if you spray .1 ounce per second or spray 2 ounces per second.. the 2 ounce per second yields a whole lot higher octane.
Nitrous is a power adder. It does not reduce outlet temps on the blower either. It adds air basically.
You want cool IAT's.. place the nozzles after blower. But not all apps is this possible. Or needed.
Most roots style blowers motors that use meth do it for a bump in octane and help with heat soak. So instead of running 14 degree's on pump gas, you run 18-20 and a few more PSI boost and not hit the knock sensor. This is how it makes power.
HTH
Old Jul 14, 2010 | 03:52 PM
Julio's Avatar
Nitrous increases an engines octane requirement. Meaning it aggravates detonation. As long as the engine runs sufficient octane then spray is not an issue. Pump gas and boost has its limits. You cant run 30 PSI boost on 87 octane then hit it with a 200 shot.
Thats why larger HP shots of nitrous are done using race fuel. boost or not.
Old Jul 14, 2010 | 04:35 PM
3.8redbird's Avatar
What is a rule of thumb on boost for octane?
say 8.0-8.5 cr what psi can I run at 13-15* timing?
Im hoping for 20-22psi then when I really want to win hit it with meth and nitrous.
Old Jul 14, 2010 | 04:38 PM
Julio's Avatar
meth is an octane kit. Not a power adder.
Ssee the point is you run 20 PSI boost. Run the meth and bump the timing to 20 degree's. Easy. Thats how you make power with meth.
Old Jul 14, 2010 | 04:58 PM
3.8redbird's Avatar
I understand that. I want to run 93oct without meth. No blower. Then with the nitrous spray meth as well for the octane bump.
I want BOTH meth and nitrous for the extra bump. Add 1-2* timing and shoot a 50-75shot and get 100-200hp jump
Old Jul 14, 2010 | 05:14 PM
Julio's Avatar
Wont work. Problem is meth wont add power. And you need stable fuel pressure with nitrous.
Yyou wont be able and keep stable pressure with a meth system. Easier to make a standalone fuel setup for nitrous. Small fuel cell, walbro 255, return line, use C16.. and watch your bottle pressure. Problem is pump, regulator, methanol, fittings, etc. Unless you washout your meth system every week.
Meth is for 99% boosted applications. On NA applications it wont work.. well waste your money. Only if you run really high compression will meth work on an NA setup. Where you can barely run on pump gas.. the meth will allow higher timing and power. Example 12:1 motor
Old Jul 15, 2010 | 01:14 AM
Uglydog56's Avatar
My brother tried a snow performance kit and a cheater kit on his roots blower. The car obviously went faster on the 175 shot. IAT's went down with the N20. So did EGT's. We left the water/meth on for street use, and switched to nitrous at the track.
