Aeromotive fuel system
Aeromotive Fuel System Part # 17125 Retails for $1443 new at Jegs.....$1100.00 shipped
Kit includes:
1) Fuel Pump wiring Kit
1) 3' 10ga Black Wire
1) 25' 10ga Red Wire
1) 30 amp circuit breaker
1) 30 amp relay
2) Blue female blade connector
2) Yellow female blade connector
5) Yellow #10 Stud ring connector
1) 3/8 Stud ring connector
6) Tie Wraps
1) 4' AN-10 Stainless Steel braided line
1) 20' AN-6 Stainless Steel braided line
1) 30' AN-8 Stainless Steel braided line
1) AN-10 90 degree hose end
1) AN-10 Straight hose end
6) AN-8 Straight hose end
4) AN-8 90 degree hose end
2) AN-6 Straight hose end
1) Fuel pump #11101
1) 100 micron ss filter # 12304
1) 10 micron paper filter # 12301
1) Fuel pressure regulator # 13101
1) Y Block assembly
2) AN-8 cutoff union
2) AN-8 0-ring
1) AN-10 cutoff to AN-8 union
1) AN-10 o-ring
12) Tie Wraps
1) AN-6 o-ring
8) AN-10 o-ring
1) AN-6 cutoff union
3) AN-10 cutoff union
3) AN-10 cutoff to AN-8 union
Addition to what comes with the kit im including:
1) AER00100 0-100PSI Fuel Pressure Gauge
10) AN-10 Cushion clamps
10) AN-8 Cushion clamps
10) AN-6 Cushion clamps
I also have a electronis fuel pump controller:
Part# 16302 $200
$1200 shipped will take the kit, controller!!!!
