Replacings pistons/rods. DIY?
Decking? Really? What do you do to your engines when removing stuff? throw wrenches at it? Drop the heads on the workbench with screws laying around? Better Plane the heads too even though you never nicked them removing them, never had a leak, never overheated, never anything... but Do it right! better get them surfaced.
There is no mention this guy track/drag races... back to the OP.
I guess our Rottler SF7M and CWT crankshaft balancer are a waste.
with good parts and comp under 10:1 motor will take 18 lb,s of boost and put a D/ shot of meth on it also.
I'm mostly concerned with, people who want to install 3.898 pistons into a bore with 50k + miles on it, cross hatch wore out. Moly rings like a smooth finish but not a glazed bore, and possibly distorted bore. The rings will never seat
the engine will eat itself up with oil consumption, detonation and you're back where you started.
With forced induction we're always battling with pushing coolant, an uneven or rough deck surface would be a good start to fix, before you try boosting.
So the two half assed rebuilds that pushed coolant and burned oil, could've had one build performed correctly and made more power.
Im honestly thinking an lq4 would be a better option since it should be able to handle a bit more boost than my ls1 can, that should hold me over for while. Thanks for all the replies guys
Harder springs? Where was this mentioned? Again, am I missing something here?
I agree.. if someone mentioned dual springs, I would agree double timing chain...
I guess all of these questions shoudl have come first. Stock setup, I would never suggest to change the timing chain. lets say Im FI, stock cam, stock 243's... im still not going to suggest a timing chain upgrade. If you think thats wrong direction, so be it.
I am correct with the honing. A super fine hone only, if any with moly rings.
I really dont see why this thread is so far off topic besides someone asking if he can change pistons and rods, turning into telling him its 3500 just for THOSE parts. maybe if its all supporting parts, but again, that was NOT mentioned. I will just read from now on, clearly assuming gets you attacked.
Yes.. you guys are all right. sorry to spread bad useless information.
Decking is a 'just to make sure' thing - oops.. sorry more bad info.
Go by AES Racing words
I never said you were polluting?
Coated Skirts? They all come like that NOT all of the them
Wrist Pins? again.. will Always come with pistons. yeah they can with the piston
Plasma Moly Rings.. most are and not much more than normally provided if that is case. they were a custom order thickness thur diamond which delayed my shipping, then I think the total seal was normal
Rod bearings Size doesnt change price. you Choose your + or -
ARP Bolts As I said, thats Included 2000 ARP.
You spent a ton of money and really tried hard to make it sound special, good work, epic fail though.
Again.. even though no one will agree with what else I say, they will agree 3500 for PARTS you list alone is nuts.
You get what you pay for
If you want to be embarrassed, list your PNs Ill call my local parts distributor here and list the prices.
See bold statement then you have to pay the machine shop to rebalance all the rotating assembly, cause the comanies have a certain tolerances and they are big if actually measure them. We go for 0grms differeance in all of my roating assembly. So after all that in parts for a smooth as butter parts then it is worth it
My parts were right around the 3500 bucks. Rings, Pistons, Rods, Bearing, and all the gaskets"
I agree, companies have a tolerance that can be reduced.
Cause I know for a fact my factory cross hatchings were still in perfect condition when I did my H/C install with 103k miles on my motor.
If factory cross hatchings are gone by 50k miles something is goin on with that particular engine as thats not typical wear for a properly maintain & running LS engine.
