crank pulley to ati damper
Old Jul 19, 2010 | 10:52 AM
cals400ex's Avatar
Default crank pulley to ati damper
i just installed my sdce crank pulley to my ati damper and i am not sure if i did this correctly. the ati damper has 12 total bolt holes. 6 of them are for longer bolts. 3 of these 6 have threaded bolt holes and the other 3 are not threaded. i did not use the threaded bolt holes. i also have A/C so that pulley is on there as well. is it ok to not use the threaded bolt holes?
Old Jul 19, 2010 | 03:17 PM
kkslds's Avatar
My sdce pulley goes through the non threaded holes into the a/c pulley that has threads in it. The dampner itself is bolted to the threaded holes on the hub. I used a little loc tite and the torque wasnt very much 30 some pounds I believe.
