having problem with aftermarket fans
Old Jul 20, 2010 | 12:54 PM
pdasterly's Avatar
Default having problem with aftermarket fans
Fans not coming on, I have two aftermarket fans, both have a positive and negative wire terminal. they worked fine before the motor swap but now I can only get them to come on if I jump the relay's with a wire. I tried swapping relays and fuses already
Old Jul 20, 2010 | 02:12 PM
elias_799's Avatar
maybe the relays you are swapping are no good, i had that problem when i burned my fuel pump relay and i tried switching it with another and that one turned out to be burned too, i was very confused for a while
Old Jul 20, 2010 | 04:25 PM
Boosted One's Avatar
Did the tune or computer get changed too? Maybe the setting is higher. Is the computer seeing the correct engine temps? ECT sensor ok? Did you switch from a 98 ecm to 99+? Do you have 12v on the opposite side of your signal wire of coil on the relay, either 85 or 86? One side should be ign+ and the other gnd signal(fan turn on) from ecu.
Frank
Old Jul 21, 2010 | 02:00 PM
pdasterly's Avatar
Tuner is going address issue, thanks
