Another cooling problem Griffin FM Turbo...
Here is the history, the build thread is in my signature. Right now I have the vertical griffin that everyone else runs in it, and a single 14 Hayden puller fan on it. That's not cutting it. It cooled better with the stock radiator and the same fan pushing through the ac condenser too.
So now I really want to fix this problem once and for all. I am thinking of ordering a single 14" Spal puller and a 10" Spal pusher to put on the passenger side but I need to know if anyone has done this and if there will be room to fit the 10" fan with the ac condenser.
I don't think I have enough room to run a shroud on the pull side of the rad. due to the turbo location. I will try to get some pics asap. Let the ideas fly!
Can you post some pics of the radiator from the top side and the bottom side as it sits right now?
is your steam port hooked up??
