bpv question
Old Jul 29, 2010 | 10:52 AM
mmorellicamaross's Avatar
Default bpv question
can you be loosing boost through a bad bypass valve, only able to get 7llbs out of my g-trim with a 2.75 pulley.
Old Jul 29, 2010 | 11:23 AM
AFASTYZFR1's Avatar
Yes, a bypass that is not functioning correctly can bleed off boost.
Old Jul 29, 2010 | 12:08 PM
is there anyway to test the bpv or do you just try and replace it?
Old Jul 29, 2010 | 03:32 PM
AFASTYZFR1's Avatar
Put pressure to vacuum nipple and make sure it closes all the way
Old Jul 29, 2010 | 03:56 PM
phatasp's Avatar
thats about all I was getting with the 2.75,I put the 2.50 on and got 9. I also thought it was low. Heads,cam,headers,intake will make a difference too.
