D1sc 630 Rwhp
You won't get belt slippage on a dyno like you will with MT/ETs out back. Until there is a load on the motor...dynos (248 dynojet) will not load the motor like street driving will. I had this much rwhp on my C5 over 1 year ago...it was great on the dyno...and even on the street when shod with street tires...put some MT/ET slicks on the car and the belt slips all over the place..that was with a 6 rib though...with the 8 rib you stand a way better chance...let us know how you do out on the strip...good dyno numbers though.
Thanks for all the compliments , I think the car is more of a testiment to Ricks creative problem solving because the kit was modified many times through the install. I guess Rick has a few more favors
coming his way.
The issue with starting at 58psi and rasing FP with boost is that you run the injectors at 70+psi under that much boost. Well that will always max them out. Is dropping the base FP an option?
BTW...nice job
BTW...nice job
with that said if he is going with REAL big injectors then droping the base presrue would get the fuel pump he has now to go a little farther. i just might not understand your question but it kind of made me wonder if i understand the whole thing.
Kyle
