need help with smoking
Old Aug 2, 2010 | 09:06 AM
camaro383's Avatar
Default need help with smoking
I installed a restrictor on the oil feed and drilled it out to 1/8", and the cars drives around fine no smoke, but sometimes after a wot pass it smokes out the exhaust when i come to a stop, i noticed one time i left a little clould when i first floored it, do u think its a drain problem or a turbo seal..
Wut do u think about the size of the oil restrictor, should i go smaller or is it too small as it is...btw i have the ls4 oil pump which i was told is a high volume oil pump, i see around 60 + oil psi at wot
Old Aug 3, 2010 | 08:30 PM
camaro383's Avatar
anyone, i know theres a bunch of these kinda posts, but just wanna see if most guys with drainback issues are having similiar problems as me
i was thinking about stacking another t4 flange under my turbo to get a little extra height, you think this is a good idea
Old Aug 3, 2010 | 09:36 PM
ls6427blown's Avatar
could be turbo or pvc system
