Best Turbo Route for 7s?
Old Aug 5, 2010 | 03:14 PM
DrTurbo's Avatar
LS1TECH Sponsor
Originally Posted by dreamls1
Thanks Doc. What does that thing max on at? Who makes the 91mm EXT-R? price?
We make them.....just give us a shout.
Old Aug 5, 2010 | 03:22 PM
transammiller's Avatar
Restricted User
twin 91s? lol
Old Aug 5, 2010 | 04:37 PM
slow67's Avatar
Gingervitis Addict
Originally Posted by Fireball
T400 are limited to stock cases..
Nothing wrong with stock cases....they have gone 6.29 @ 221MPH.....Aftermarket cases will be out soon.
Old Aug 5, 2010 | 04:57 PM
LASTLS1's Avatar
6 Second Club Moderator
I run a Rossler 400. I've never had a problem.
Old Aug 5, 2010 | 05:11 PM
dreamls1's Avatar
Thanks for all the imput on the trans guys!
Now how about the turbo set up? Dr turbos set up sound pretty nice!
Old Aug 5, 2010 | 07:31 PM
Shawn @ VA Speed's Avatar
While a 91 is capable of running 7's in a racecar that has a maximized combination-i don't see it happening in a 3500 lb street car.The margin for error is too small.While i agree that most people over turbo engines-it is much easier for a novice to err to the larger side.
Old Aug 5, 2010 | 08:42 PM
98Z28CobraKiller's Avatar
Restricted User
I must vigorously concur. Are there any size limits in that true street class? Unless you're limited to 91mm, you should go bigger to go 7's for sure. Trust me that having the power to run a 7 is not enough to run a 7. You dont want to be on the edge powerwise while trying to work out your other issues. The power is the easy part.
Old Aug 5, 2010 | 09:00 PM
dreamls1's Avatar
Shawn, what do you turbo do you suggest?
There is no limit to turbo size, my worry is not being able to spool it off the line with a 106. That's why is was thinking of going twins, although I would rather have a single.
Old Aug 5, 2010 | 09:42 PM
DrTurbo's Avatar
LS1TECH Sponsor
If you want something that will spool well and make 1300+rwhp simply go with a GT-98 from Garrett. We have customer's easily running 4.8's@150+ with them. The GT55 turbine (which the pro-mod also uses) are a touch on the small side from the backpressure #'s we are getting on customer setups if you plan to go hard on the turbo.
Old Aug 6, 2010 | 08:03 AM
dreamls1's Avatar
Is the GT-98 the thumper unit?
Old Aug 6, 2010 | 08:50 AM
Pro Mod 94-will easily get you there.if the engine is built right and the proper converter is used-you will have no issues.Spool easy and no backpressure problems
Old Aug 6, 2010 | 09:38 AM
  #32
dreamls1's Avatar
What stall? I have a 3400 now, ok? Gears are 3:50s. Rememer this car has to drive 30miles before racing
Old Aug 6, 2010 | 10:33 AM
  #33
DrTurbo's Avatar
LS1TECH Sponsor
Yes...but the Garrett versions are basically the same size as the GT55's. You will have much less backpressure with the F-trim based unit, over a GT55/Pro-mod.
Old Aug 6, 2010 | 12:52 PM
  #34
dreamls1's Avatar
Soo, The GT-98 is my best bet? Thats what i am getting from all this. This motor is going to have low compression.
Old Aug 6, 2010 | 08:04 PM
  #35
converter is determined by alot of factors-engine size,cylinder head size,compression,camshaft,turbo size,gear ratio,car weight,tire size.
gear ratio is dictated by engine rpm and tire size.
