twin turbo lt1 z
For twins - 60-1 w/62mm turbine
Single - 76mm with 75mm S wheel exhaust
The TC series with the 68mm turbine wheel will meet your HP goals -should have a reverse split custom cam or a small conventional cam and will support the least amount of HP based on the smaller turbine.
A 219/219 113 lsa custom billet lunati voodoo series is a good compromise.
Check into what power level the stock style intake becomes an issue. They eventually have fuel distribution issues and the back runs lean.
