What intercooler are you guys running
Old Aug 15, 2010 | 01:10 PM
EvilStang's Avatar
STF Veteran
Default What intercooler are you guys running
Im starting my latest build and im very new to this forced induction stuff ( nitrous was my friend). its going to be a forged lq9 with a s475. Ive done alot of searching and seen alot of setups. I was just curious as to what you guys would recommend for a intercooler.
Old Aug 15, 2010 | 02:56 PM
rjparth's Avatar
A lot of people use the units commonly available on eBay, CXRacing I believe. Another popular type is the Mishimoto. I believe the G Line is what fits our cars. That's what I have. Here is a link that explains all about intercooler theory, design, construction etc. http://www.turboneticsinc.com/sites/...tercooling.pdf
I installed my Mishimoto G Line pretty easily and have pics if you're interested. I've seen some guys remove a large section of the front bumper support and install the intercooler inside the remaining support bracket. I didn't find that to be necessary and instead made simple brackets from heavy gauge Home Depot sheet metal.
I'm still gathering data and getting other bugs worked out so I don't have any solid IAT data for you. If money was no object I'd probably look at the Spearco's.
Old Aug 15, 2010 | 03:16 PM
The Beast's Avatar
ebay.
Old Aug 15, 2010 | 03:17 PM
TurboAv's Avatar
If you are going to go with a high quality core get a Garrett. Shearer makes a sweet setup using a 24x12x4.5 Garrett core. That being said, for a streetcar on a budget, the cheap Ebay units work great.
Old Aug 15, 2010 | 03:34 PM
9sectruck's Avatar
cxracing cooler, it comes out of my blower at 280ish and the intercooler brings it down to 130s, then meth on top of that
Old Aug 15, 2010 | 04:01 PM
buick_lsx's Avatar
i have a 6.0 with s475 as well, and i use the cxracing a2w intercooler (1200 hp version) and a "heat exchanger" almost as big as my radiator.....idk what the temp coming out of the turbo is but my iat's are only 5-10 degrees above ambiant
