Making the switch from Procharger to Turbo
Old Aug 16, 2010 | 07:42 PM
dschmittie1's Avatar
Default Making the switch from Procharger to Turbo
So since my D1 met its untimely demise due to a bearing failure that took out the impellar, input and output shafts. After lots of consideration I decided that I was gonna make the plunge into a Turbo build. I have never tackled a project like this before let alone much fab work. So in Prep for this build I purchaced a welder and started practicing.
So here is the Plan Keeping the Forged 347 with home ported 243 heads with a 1.60 exhaust valve and stock intake valve. Vic Jr intake and Aarons Elbow. I am changing out the cam to a Turbo cam that Shawn @ Virginia Speced is Specing for me. Gonna be a slight variation of one of there shelf cams to help spool my Turbo.
Now to the fun part. The kit is gonna be a truck manifold based Front mount PT88. With a 4 inch down pipe. I got the Turbo in last week and started fabricating the hot side this weekend. I have the Cross over tacked together and almost ready for final welding. I still need to get a Waste Gate and plumb that into the crossover before I finish welding the Crossover.
I have also been busy building a new Support for the Intercooler. Cutting out the upper rad support in prep for the radiator to be stood up and just working on some things to take some weight out of the car.
There will be more to come. Not in a big hurry to get this back together. If it gets done in time to come out this fall that would be great but I am looking more to have it ready for early next year.
Old Aug 16, 2010 | 07:57 PM
1fast bird's Avatar
Wow you aren't messing around! Looks really good so far Dan!
Old Aug 16, 2010 | 09:11 PM
XtremeDime's Avatar
Should make another crossover and send it to me. lol
Old Aug 16, 2010 | 09:15 PM
haha I don't have sway bar to work around although I think I have kept this up high enough that it would clear a sway bar if I still had one
Old Aug 16, 2010 | 09:17 PM
Zero4488's Avatar
Restricted User
Looks absolutely incredible....possibly interested in making them for a few of us?
Old Aug 16, 2010 | 09:36 PM
99Z28LS1's Avatar
Set up looks great, it's ok to have slag on the outside... but just make sure there isn't much on the inside of the pipes... it could lead to small pieces falling off and getting in the impeller
Old Aug 16, 2010 | 10:32 PM
WS6HUMMER's Avatar
You tacking that with flux core mig?
Old Aug 17, 2010 | 01:25 AM
sixpack_2_go's Avatar
that intercooler support looks very nice! you should consider making more and marketing them. they would sell like crazy!
Old Aug 17, 2010 | 05:18 AM
yes. I just bought the welder like 2 weeks ago. I will be picking up a tank of shielding gas next week and changing wire before I finish up all the welding
Old Aug 17, 2010 | 06:23 AM
pber13's Avatar
that's what I was thinking. just double check before you bolt everything together and fire it up. everything sure looks damn good though, especially if you only just started welding this kinda stuff recently. I'm impressed!
Old Aug 17, 2010 | 06:56 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Looks like a very nice and simple set-up. I'll have to follow this one! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Aug 17, 2010 | 07:16 AM
JAX04's Avatar
very nice
what radiator is that?? i see its a griffen, just curious if its new to this build or if its a previous piece. work ok? model number??
Old Aug 17, 2010 | 07:20 AM
Originally Posted by JAX04
very nice
It is a new peice to this build. I am not sure of the part number but it is the radiator that everyone uses when they stand them up. I got the part number from a thread on here
Old Aug 17, 2010 | 07:21 AM
JAX04's Avatar
cool. thanks man. good luck with the project, i will keep a close eye on this, interested to see how the 88 does on the 347.
EDIT: you think you could tell me the dimensions on that??
Old Aug 17, 2010 | 12:26 PM
LS1RedZ's Avatar
Sorry to hear about your procharger failure. The turbo build is looking good. If I had the money I would be doing the same thing. Swapping from my D1SC to a truck manifold kit.
Old Aug 17, 2010 | 12:33 PM
Well It worked out o cost me less to build the turbo kit then buy another blower with all the stuff I could sell off the car. Plus having a Friend that got me the Turbo at wholesale cost instead of list was nice
Old Aug 17, 2010 | 09:43 PM
trans2000am's Avatar
make sure u brace that turbo
Old Aug 17, 2010 | 10:12 PM
ebeard's Avatar
Subscribing.
Old Aug 18, 2010 | 06:26 AM
I am planning on bracing it to the motor somehow. Just not sure where yet.
I picked up a tank a sheilding gas last night. switched wires in my welder. Cut all the shitty tacs out of the pipes from the flux core wire and re tacked things together. Also spend some time practicing welding some scrap peices of pipe together to figure out the settings on the welder.
Old Aug 18, 2010 | 10:08 AM
99Z28LS1's Avatar
That's how I taught my self... Picked up my old Y pipe and cut it into a million pieces. Although I started with a TIG... I like the process/outcome much better. GL!
