cam and head combo on a turbo ls1 question
Old Aug 23, 2010 | 09:25 PM
vogun16's Avatar
Default cam and head combo on a turbo ls1 question
i can get a pretty good deal on a set of low milage 6.0 heads with brand new set of partiot dual gold springs on them and a brand new Isky turbo cam specs are
215/215, .566''/.566'', 114*
i dont know much about specs on a cam but i was told these are good.
its a stock ls1 with a t70 turbo intercooled running 9lbs.
just curious to know if this would be a good set up for my car and what kind of power difference i might see thanks!
Old Aug 23, 2010 | 09:37 PM
tripblackls1's Avatar
what size motor is it? stock ls1?
that cam is a lil small for ls1 cubes and it does not have a split to help get that exhaust out
but hell im sure its better than a stock ls1 cam
Old Aug 23, 2010 | 09:45 PM
vogun16's Avatar
haha ya its a stock ls1. problem is that one day i want to put a stock 6.0 in it one day.. whats a good cam for a turbo set up??
Old Aug 23, 2010 | 10:12 PM
well im by far not a cam expert but from my experience a 224/230 on 116 is a nice mild boost cam for stock cube ls1
and if you plan on putting a 6.0 in it one day you should really put some forged internals in it or its not really going to benefit you, just add weight to your car lol
and if you do forge it then you have the option of adding more cubes (like a 408) and you would want a whole different cam for that motor
Old Aug 23, 2010 | 10:34 PM
vogun16's Avatar
thanks that helps alot! i was going to keep my stock ls1 but i was told the 98 cylender walls are thiner?? weather thats true or not i dont know.. my original plan was to forge my motor but then i was told to either get a different year block or a 6.0 so i figured i would get the 6.0 lol
Old Aug 23, 2010 | 10:48 PM
vogun16's Avatar
so i looked up the cam specs you just gave me and according to LEPs website they say it is a supercharger cam... the turbo cam they have has these specs..
LEP's most popular turbocharger cam. Proven results.
595 595 236 234 117LSA For turborcharger applications. 2200-7300 RPM Power Band. Builds boost quick. Excellent idle manners
